An attempt to remove the resource for a conduit event failed. The resource was not found in the database. The system will continue managing and processing resources for other events.
This is possibly the result of internal data corruption or a software programming error. Report the problem to your switch support contact.
Error
An attempt to remove resouces associated with a conduit message for slot %slotId% conduit type %conduitType% failed - resouces could not be found.
| Name | Type |
| slotId | uInt |
| conduitType | String |
